Engine idle too high. erratic idle.
PLYMOUTH
ESGAROTH
  • 11 POSTS
1988 Plymouth sundance.
2.2 fuel injected (tbi)
When I start the car the idle will go up to about 1000 rpm. I think normal should be about 250 - 500. Idle is almost smooth but is a little bit rough. If I drive around the block and then park, the idle will be around 2000 rpm.
I have been over the whole vacuum system. I have replaced bad hoses and got rid of all the plastic hoses.
Oxygen sensor is new.
Plugs and wires are new.
compression is 130 - 150 in all cylinders.
fuel pressure is normal - 14.5
What else should I check?
May 21, 2006 at 9:05 AM
SNOW
  • 10 POSTS
check your throtle cable and the connection to the tbi check if throtle is getting stck open
Jan 12, 2007 at 4:42 AM
