1990 Plymouth Sundance Signal Flasher Fix
1990 PLYMOUTH
TP123
I cannot seem to locate the signal light flasher on my 1990 Plymouth Sundance. I can locate the harzard flasher, horn relay and ignition delay relay. These are all located together but for some reason on there is no signal flasher next to these. There appears to be an empty two prong area on the mounting unit but no wires going into it and I cannot find any unconnected wires around the mounting unit.
Is there somewhere else this could be located.
All signal lights light up but I have a solid light on the singal indicator. Being that I have a solid light would this mean that there is no break in the connection and that there is a flasher connected somewhere?
Has anyone run into this before and any suggestions were exactly to look under the dash?
Mar 12, 2006 at 12:20 AM
JPAM
  • 307 POSTS
both sides not working?? having a signal light out while cause a solid indicator light..
try this links and if they help. good luck.. jess s
Mar 13, 2006 at 9:16 AM
TP123
Both sides do not flash and have a solid light on the indicator. The lights appear to be working , also I do not hear a clicking sound to help locate the flasher.
Mar 13, 2006 at 10:10 AM
JPAM
  • 307 POSTS
did you check those links... they might help
also ddid you check fuses to sure?
Mar 13, 2006 at 10:16 AM
TP123
The link did not work earlier from my last reply but I tried again and from your link I found the flasher, replaced with a new unit and all is well!
I had to take out the glove box and to the right behind the radio/heater controls there it was...
Thanks for your help I had spend a couple of hours under the dash on the weekend trying to locate this. If you had not tipped me to the glove box area I don't think I would have ever thought to take it out to get behind it!
Mar 13, 2006 at 12:20 PM
JPAM
  • 307 POSTS
hey no problem.. i wasnt really sure myself.. i just know that they really like to hide the dang thing..
thanks for reposting.. Glad I could help..
jess s.
Mar 13, 2006 at 7:34 PM
Suggested Repair
Remove the glove box and locate the turn-signal flasher to the right, behind the radio and heater controls. Replace the flasher if both sides stay solid, do not flash, and there is no clicking.
Conversation Summary
The owner of a 1990 Plymouth Sundance could not find the turn-signal flasher near the hazard flasher and relays. Both sides stayed solid, the indicator did not flash, and no clicking was heard. After checking the suggested information, the owner removed the glove box and found the flasher behind the radio and heater controls. Replacing it restored normal flashing.
