What fuse do I change in the fuse box? or is it the brake light switch if its not the fuse?
Sep 6, 2006 at 3:09 PM
DARKMUSHROOM901
MEMBER
well your owners manual should tell you fuse wise but if its not a fuse it could b 2 other things, a the pressure on the master cylinder isn't set right for the lights or the wires may have shorted.
