94 Sundance Right Turn Siginal
UNKNOWN69
  • 1994 PLYMOUTH
I have a 94 sundance 2dr hatchback had to replace a bad rear right turn siginal socket now everything is fine as long as the headlights are off as soon and the headlights go on the blinker freezes in the on position but when I turn the headlights back off everything goes back to normal
Saturday, November 10th, 2007 AT 3:35 PM
  • 109,772 POSTS
What socket did you replace? Does the other side signal work?
Friday, March 20th, 2009 AT 10:27 AM
CARADIODOC
  • 33,879 POSTS
Classic symptom of a bad ground. There's two signal bulbs on each side on the rear. With a bad ground in one socket, current goes through one filament, (can't get to ground), goes through the tail light filament, over to the other bulb's tail light filament, to ground in that socket. When you turn on the head lights, (just the running lights), the turn signal with the bad ground has 12 volts on both sides of the filament so it goes off.
You should also see the two signal lights on that side blinking alternately when there's a bad ground.
Caradiodoc
Sunday, March 29th, 2009 AT 10:06 PM
