1988 Other Plymouth Models lights
1988 PLYMOUTH
112,000 MILES • 4 CYL • FWD • AUTOMATIC
SHANE STONER 0328
I own a 1988 Plymouth Sundance, and i turned it on and went to turn on the headlights and the speedometer light did not turn on and neither did the a/c and heat unit light, nor the two front yellow lights, the turn signals worked fine but the yellow lights did not come on with the headlights. I checked all the fuses and there all fine and I'm pretty sure its not the battery, so I'm stumped, and its pretty hard to see where the needle on the speedometer is at night so i really hope you can offer some advice thanks guys.
Jun 11, 2008 at 9:48 PM
  • 110,244 POSTS
Hi:
The lights on the front most likely need replaced. As far as the dash lights, you will need to check for a bad ground or try to remove the bulbs and replace.
Let me know what you find.
Oct 16, 2008 at 2:41 AM
