2000 Other Plymouth Models Valve Cover Gasket
2000 PLYMOUTH
JKTHEALIEN
Engine Mechanical problem
2000 Other Plymouth Models 4 cyl Front Wheel Drive Automatic
How do you change the valve cover on this car? I have heard there are o-rings somewhere to keep oil out of the cylinders or spark plug area. Is this true and if so, how do you change them. Thank you,
Jeff
Oct 7, 2008 at 11:30 AM
  • 110,244 POSTS
What model is the car and I need the engine size. As far as replacing O rings, they will simply be placed into a spot in the casting made for them.
Mar 22, 2009 at 9:04 AM
