1999 Other Plymouth Models radiator fluid
1999 PLYMOUTH
106,000 MILES • 4 CYL • FWD • AUTOMATIC
ASTROID
There is oil in the radiator fluid. What can cause that?
Aug 23, 2008 at 10:08 AM
  • 110,244 POSTS
Hi:
If it's motor oil, the head gasket may be bad. If it's transmission fluid, there may be a crack in the trans cooler (part of the rad) allowing ATF to get in with the coolant
Oct 13, 2008 at 5:09 AM
