1999 Other Plymouth Models bad water pump
1999 PLYMOUTH
JBURLESON
1999 Other Plymouth Models Automatic
I have a '99 Plymouth Neon DOHC 2.0L & on saturday it sounded like i hit something as i was driving to my friends house the car road fine and when i was leaving her house i noticed alot of water on the ground again on the way home the car ran fine i stopped at the store and when i started the car back up it sounded like I needed an oil change then on the way home it just started coasting til i turned it off now it will not start. I didn't overheat but as you put water in the radiator it runs right out. I was told it was a bad water pump and that i should replace the timing belt as well. What are the possiblities of me also having a blown head gasket?
Nov 4, 2008 at 4:22 AM
  • 75,988 POSTS
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 4, 2008 at 4:33 AM
