1998 plymouth venture
1998 PLYMOUTH
LIPS2SWEET
we are having problems with my van i have no brake lights in the rear...we have changed the switch and checked the bulbs and still arent working....my ABS light has been on for about 2 weeks but had brakes then...not sure what is wrong can somebody help
Apr 15, 2007 at 9:51 AM
BOOTDOG
  • 665 POSTS
check the fuses.
Apr 15, 2007 at 11:55 AM
LIPS2SWEET
sorry we did that already also...the fuses are all good
Apr 15, 2007 at 1:24 PM
BOOTDOG
  • 665 POSTS
the abs light can be checked with a scanner from a local repair shop that does diagnostics. if you checked all the possibilities, then the next thing to check for is bad grounds, loose connections, or even broken wires. hope this helps
Apr 16, 2007 at 11:34 AM
