i have a 1998 plymouth neon it is pouring coolant from behind pulleys what is the part and how do i change it
Oct 19, 2008 at 1:58 PM
BLACKOP555
✓ASE Certified Mechanic
is it coming from around a pulley or is it coming from the enine block or froma resevoir? you are a bit vague on your question.
Oct 19, 2008 at 2:59 PM
KENT267
MEMBER
i figured it out it is the water pump pouring into the timing belt cover and out i have started tearing it apart and it is the biggest pain in the #@%$^%*& i have ever come across the pump is ran off of the timing belt so i am replacing everything thanks for the response
Oct 20, 2008 at 12:50 AM
BLACKOP555
was hoping it wasnt that, sorry that is is. but at least you know what is wrong if you need help i can try to be all the help i can. if you need a diagram i can try and find it if it woudl help you. take pictures and remember.
Oct 21, 2008 at 8:16 PM
