1998 Other Plymouth Models reservoir?
1998 PLYMOUTH
128,000 MILES • 4 CYL • FWD • AUTOMATIC
KENT267
i have a 1998 plymouth neon it is pouring coolant from behind pulleys what is the part and how do i change it
Oct 19, 2008 at 6:58 AM
BLACKOP555
  • 10,386 POSTS
is it coming from around a pulley or is it coming from the enine block or froma resevoir? you are a bit vague on your question.
Oct 19, 2008 at 7:59 AM
KENT267
i figured it out it is the water pump pouring into the timing belt cover and out i have started tearing it apart and it is the biggest pain in the #@%$^%*& i have ever come across the pump is ran off of the timing belt so i am replacing everything thanks for the response
Oct 19, 2008 at 5:50 PM
BLACKOP555
  • 10,386 POSTS
was hoping it wasnt that, sorry that is is. but at least you know what is wrong if you need help i can try to be all the help i can. if you need a diagram i can try and find it if it woudl help you. take pictures and remember.
Oct 21, 2008 at 1:16 PM
