1998 Other Plymouth Models Recently had new filter and fluid
FRANKGORSHIN
  • 1998 PLYMOUTH
  • 4 CYL
  • FWD
  • 186,000 MILES
Old fluid was brown and it has been a couple years since the filter was changed.
Had the filter and fluid changed yesterday. Today going to work, while the car 'runs' smoothly, there are annoying spikes in the acceleration, the passing gear pops in and out, and the speedometer won't work most of the time.
The speedometer thing makes the speedometer jump, register only a percentage of the speed, or not register at all.
I 'think' and it is only an educated guess maybe there is too much fluid in the tranny. I really think I need it looked at.
Tuesday, December 2nd, 2008 AT 5:13 PM
  • 109,885 POSTS
Hi:
Was it the trans that was serviced? If so, check to see if any vacuum lines or sensors were disconnected while they worked on it. Also, check the trans fluid with the engine hot, ideling, and on a flat surface. It may need checked in park or neutral. If will say on the dipstick.
Let me know what you find.
Sunday, March 22nd, 2009 AT 3:51 PM
