1998 Other Plymouth Models Fan motor relay switches
1998 PLYMOUTH
ARTISTD
Electrical problem
1998 Other Plymouth Models Automatic
I have a 98 Plymouth Grand Voyager,3.0 engine. My fan motors are not working and I need to change the relay switches but I am not sure how to do it. Can you please tell me how I do this.
Thanks
Sep 5, 2010 at 2:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the cooling fan relay is behind the left headlamp assembly, you'll have to pull headlamp and find it under a plastic shield . once accessed you just unclip from location to replace.
Sep 5, 2010 at 4:01 PM
ARTISTD
Is there one or two relay switches? Everyone says you need two since there is a small and big fan for the radiator. Is this true? If I need two are they both behind the headlights?
Thanks for you help
Sep 5, 2010 at 6:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
nope just one radiator fan relay on the fans circuit. if the relay is good and fuses good then either wiring is bad or PCM could be at fault.
Sep 6, 2010 at 12:58 PM
