hi:
If there isn't a screw in the center, then most likely there is a large C-Clip holding it from the rear between the panel and the handle. There is a special tool to remove it, but is you can fit a small screwdriver behind it and locate it, you may be able to get it to pop off. Of not, most auto body shops have the needed tool. I'm sure someone would let you rent or borrow it for a couple minutes.
Mar 22, 2009 at 2:32 PM
