1997 Other Plymouth Models Oil in spark plugs
1997 PLYMOUTH
170,000 MILES • 4 CYL • 2WD • MANUAL
DCHESEBRO02
I just bought a 1997 plymouth neon and was changing out the plugs and wires and noticed there was oil on the plugs. it got thicker as I changed the fourth plug, what does this mean? is this fixable? reach me here or at dchesebro02@yahoo.com.. thank you in advance
Sep 7, 2008 at 11:21 AM
  • 110,244 POSTS
Hi:
Based on how many miles are on the vehicle, the rings may be getting bad. If it runs ok, I would just use it the way it is unless you feel there is a hazard. If you want to know, have a compression test done to see if the rings are bad. Keep in mind, the compression rings may be ok and the oil rings could be worn.
Oct 13, 2008 at 3:45 AM
