1996 Other Plymouth Models Wacky Speedometer
1996 PLYMOUTH
NEONITE
1996 Other Plymouth Models 83,000 miles
Several months ago my Neon began having trouble with the speedometer. It will suddenly stop working and drop to zero. This will continue for anywhere from a couple of minutes to a couple of hours and then it will spontaneously start working again. Less frequently, the fuel gauge and tachometer will go out as well. In the beginning, it seemed to be at least temporarily resolved by thumping the top of the dash, but that hasn't been working as of late. Putting pressure on the clear plastic front would also work, but as soon as the pressure was removed, it would drop back to zero. Any ideas what's going on?
Oct 10, 2008 at 4:41 AM
BLACKOP555
  • 10,386 POSTS
sounds like the instrument cluster is faulty due or the wiring harness is loose/disconnected/damaged and thumping on it and moving the cluster helps it work.
Oct 10, 2008 at 7:34 AM
