1996 Other Plymouth Models Shifting
1996 PLYMOUTH
MATSUURA7
1996 Other Plymouth Models Two Wheel Drive Automatic
I sometimes have to wait several seconds after starting the car in order for it to shift into reverse. Sometimes I even have to tap the gas so it finally shifts. Is there any way I can fix this?
Oct 27, 2008 at 10:16 AM
  • 110,244 POSTS
Have you checked to make sure the ATF is full? Also, was the trans serviced reciently? Finally, once it works, does it seem to work properly?
Mar 22, 2009 at 8:58 AM
