1996 Other Plymouth Models Radiator Fan
1996 PLYMOUTH
125,000 MILES • 4 CYL • FWD • AUTOMATIC
HJRUIZ2
I have a 1996 Plymouth Neon 2.0 SOHC. The fan on the driver side doesn't work but the other one works ok. Should both fan run at the same time when the rad fan relay is turned on?
Sep 27, 2008 at 5:22 AM
  • 110,244 POSTS
Hi:
Check if there is power to the motor that doesn't run. If there is power, chances are the motor is bad.
Oct 13, 2008 at 3:03 AM
