1993 Other Plymouth Models Rough,and Shaky
1993 PLYMOUTH
145,000 MILES • 4 CYL • FWD • AUTOMATIC
JAZDO
My daughters 1993 Sundance has a problem when started it idles very rough.When put into drive or reverse its even worse! Hardly any power.
I checked the code using key method and it gave a 35 error which is cooling fan relay circuit open or shorted. Also gave a 55 which is end of code.
I put a new fuel pressure reg. on it because it was leaking,also a new fuel filter. I also noticed a leak from the bottom hole that is on top of carburetor. Not sure what it is called. The bottom hole looks like it is plugged for some reason and a small crack developed,but last I checked it is not leaking now.
Not sure we don't drive it now. Any help appreciated
Jul 9, 2008 at 1:02 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi:
First, make sure the throttle body (carb) doesn't have a vacuum leak where the hole is. Next, check for other vacuum leaks. Finally, have the temp sensor checked and replaced if needed.
Let me know what you find.
Oct 16, 2008 at 9:37 AM
