1993 Other Plymouth Models 93 Laser overheating.
1993 PLYMOUTH
MAXWELL33
Engine Cooling problem
1993 Other Plymouth Models 4 cyl Front Wheel Drive Manual 184/k+ miles
I have a 93 Plymouth Laser, and i just replaced the radiator, fan sensor, alternator, and battery. The problem is the fans are not turning on. After i replaced the sensor they kicked on when the temp gauge reach the half way point while sitting in my driveway. I took it around the block and the fans wouldn't come back on, and the temp gauge was almost maxed. What could it be?
Sep 20, 2008 at 11:20 AM
  • 75,988 POSTS
Check the cooling fan thermosensor located in lower right rear of radiator. Also see below
https://images.2carpros.com/forum/automotive_pictures/12900_sensorgauge_sending_unit_1.jpg
Sep 20, 2008 at 11:43 AM
