1993 Other Plymouth Models
1993 PLYMOUTH
130,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBTOBI6
i have a 93 plymouth laser that wont stay chared
i have replaced the alternator and the battery also
replaced the starter
Oct 17, 2008 at 11:39 AM
  • 110,244 POSTS
Hi:
Have you had the voltage regulator replaced or checked? If you have any everything is ok, there must be a short or something causing a drain to the battery. If you have a digital volt meter, remove the positive terminal from the battery and use the volt meter as a bridge between the positive cable and the positive terminal. You should have a very slight draw on the battery if everything is off.
Let me know what you find.
Oct 28, 2008 at 4:11 AM
