1992 Other Plymouth Models oil leaks
1992 PLYMOUTH
120,000 MILES • 4 CYL • 2WD • MANUAL
MGHURTZ1
I have a 1992 plymouth laser 2.0 manual non turbo that is leaking around the oil filter bracket. It is pouring out when i start the motor. I have checked the belts and timing cover area and they are clean from oil. I cant tell if the oil filter bracket is leaking from the top and leaking down or from some where else in that general area.
Aug 22, 2008 at 6:27 AM
  • 110,248 POSTS
Hi:
Get engine cleaner, degrease the engine, then watch for where the leak is coming from.
Oct 13, 2008 at 5:51 AM
