1991 Other Plymouth Models Missing
1991 PLYMOUTH
44,000 MILES • 4 CYL • FWD • AUTOMATIC
PHANTO221
I got my car and it gave me minimal problems, but recently i have had a bad problem with my engine. when i Hit the gas it is very hesitant and takes a very long time to accelerate, with the occasional Popping noise in the front. I've replaced my fuel filter, put new spark plug cables, re gapped my spark plugs, fixed my timing and put tekkron in the tank.. but it is still giving me the same problem. My thermostat says the car is running at an even temp. and the check engine light is not on. is there anything else i should check before i have to spend a ton on replacing my fuel injector?
Mar 30, 2008 at 1:31 PM
Inspect and test the throttle position and the MAP sensor
Mar 30, 2008 at 7:36 PM
