1990 Other Plymouth Models no fuel no spark
1990 PLYMOUTH
GREENROOT22
Electrical problem
1990 Other Plymouth Models 4 cyl Two Wheel Drive Automatic unk miles
the other day the car died and now gets no fuel and no spark, at first i replaced the relays, fuel pump, fuel filter, dist cap, rotor, wireset, had my battery checked, havn't managed to get the coil checked, and was advised that it should be the computer. but i've heard that it is possible for the computer to be good but it's going to get expensive real quick and i have work to get to. the wires to the coil don't seem to act right and the fuel pump gets no power. should i try the coils first, or should i skip that and goto replace the computer.
Mar 17, 2008 at 7:32 AM
You didn't mentioned the model-look for the ASD relay if it has one and test it out-this relay powers the coil/injector/fuel pump thru the fuel pump relay-
Mar 17, 2008 at 10:12 AM
