1987 Other Plymouth Models Air conditioner condensation
1987 PLYMOUTH
NCARTER
Air Conditioning problem
1987 Other Plymouth Models V8 Two Wheel Drive Automatic 130k miles
I have a lot of water coming out of my floor vents when I run the air conditioner. I think the drain is plugged but it almost seems excesive. If I drive for an hour I will have about a cup to two cups pour out. Is this normal and where would the drain be located?
Jul 11, 2008 at 7:02 PM
MICKEY-D
  • 304 POSTS
No it's not excessive, and the drain is on the passenger side either coming out of the firewall in the engine bay or fender well area. If you are mechanically inclined, you could take off the cover for the heater core and clean the drain from the inside. mickey-d
Feb 23, 2010 at 5:56 AM
