1985 Other Plymouth Models
1985 PLYMOUTH
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
CSGOLDMAN
every morning when i Leave to go to work it gives me hell. its wanting to stall in first and second gear. its like its not wanting to change gears AT ALL. when it does this its like i am taping the brake every time i press the gas
Aug 12, 2009 at 1:24 AM
HMAC300
  • 48,601 POSTS
if this has a carburetor, see if the choke plate is closing a it should an open a little so it won't stall. Also alot of those 4 cyl chrysler products the gasket under the carb would go bad and leak vacuum. It is kind f a rubberized gasket and thick. if it's not something like that then it may be a trans problem.....
Feb 8, 2010 at 12:03 PM
