1974 Other Plymouth Models
1974 PLYMOUTH
STEVO1963
1974 Other Plymouth Models V8 All Wheel Drive Manual
i have a lifter that doesnt operate when engine is started and when i push on the pushrod with my finger there is very little resistance
Aug 6, 2008 at 3:57 AM
  • 110,244 POSTS
Hi:
If the lifter is collapsed, it will need replaced. However, you said it didn't work when the engine is running. The cam may have a worn lobe. You need to check it prior to putting money in to the car.
Oct 13, 2008 at 6:27 AM
