1966 Other Plymouth Models Fuel Gauge wiring for 1966 Fury 3
1966 PLYMOUTH
50,000 MILES • V8 • 2WD • AUTOMATIC
BINO BROWN
I have on the back of my fuel gauge 3 connects.
First one labeled "A" second is "I" and third is "S". I want to wire it up so I won't have to keep fueling when not necessary.
Feb 1, 2008 at 8:54 AM
HMAC300
  • 48,601 POSTS
obviously your gauge doesn't work. See if there is power going to the fuel sender. If there is -it should be a blinking light and when you put your tester on it your gugage should start to rise- replace the sender instead of screwing your wires up and causeing other problems.
Nov 13, 2009 at 1:01 AM
