Plymouth Neon
PLYMOUTH NEON
HERNANDEZ52
Interior problem
Plymouth Neon 4 cyl Two Wheel Drive Automatic 138897 miles
I am having problems with my 1996 plymouth neon. The gas, temperature, and gas needle is not working. The car runs fine but i have no idea how fast im going, how hot or cold it is, and if i have gas or not? I checked the fuse box but all the fuses seem fine.
Aug 17, 2010 at 1:07 AM
JDL
  • 16,098 POSTS
I'd use a voltage tester on the applicable fuses to see if there is voltage. Also, could be problem with cluster itself.
https://images.2carpros.com/forum/automotive_pictures/170934_neon_fuses_1.jpg
Aug 17, 2010 at 1:40 AM
