2001 Plymouth Neon MY HORN
150,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGDEETA
WHY DOESN'T MY HORN WORK? WHEN I USED TO SWITCH THE RELAYS ON THE ELECTRICAL BOX UNDER THE HOOD IT WOULD WORK PERIODICALLY? DO I NEED TO REPLACE THE ELECTRICAL BOX?
Feb 4, 2010 at 5:26 AM
JDL
  • 16,098 POSTS
Hi, I'd pull the relay and check the voltage circuits at the relay terminals. Two circuits are hot all the time. The problem is usually the wiring circuit in the steering column.
Feb 4, 2010 at 5:39 AM
