2001 Plymouth Neon engine hessitates
2001 PLYMOUTH NEON
65,000 MILES • 4 CYL • FWD • AUTOMATIC
COGBURN
when driving in traffic and try to accelerate engine motor seam to misfire loss power chech engine light will flash let off of accelerater motor will respone and light will go out seem to run ok
Nov 25, 2009 at 9:28 AM
Scan the computer for code/s this is your starting point finding out what's going on
Possible Causes of Engine Hesitation or Stumble:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 25, 2009 at 10:22 AM
