2001 Plymouth Neon brakes
2001 PLYMOUTH NEON
SUNSHINE05
2001 Plymouth Neon 4 cyl 115000 miles
the right side brakes are not working but the left side is working fine..we bleed the brakes and the right side had no pressure.when drove the car it pulled to the left when stopping..brakes are new and good. What would cause this???
Aug 3, 2010 at 2:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Is your brake warning light on? Sounds like you need to center the valve inside the proportioning valve. It slid over and is blocking the fluid flow to that side of the brakes.
Aug 3, 2010 at 3:09 PM
