2000 Plymouth Neon valve train rattling sound at idle
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
DCHICKS
Valve train rattling at idle and knocking sound. The engine performs well and all proper maintenance service has been done . Should i be concerned ?
Mar 19, 2009 at 1:16 PM
  • 75,988 POSTS
Best be concerned if you don't want a major repair to happen get it check now. Following could be causing your problem.
A clicking or tapping noise that gets louder when you rev the engine is probably "tappet" or upper valvetrain noise caused by one of several things: low oil pressure, excessive valve lash, or worn or damaged parts
Mar 19, 2009 at 8:43 PM
