2000 Plymouth Neon starting
2000 PLYMOUTH NEON
91,000 MILES • 4 CYL • FWD • MANUAL
BRANDONLEE22
My car hasn't been run in about 6 months. I went out to start it and it catches on the first turn over and then won't catch after. I have replaced the spark plugs and the coil. the fluids are good and it has a half tank of gas. I can't figure it out. the fuses are all good. what do you suggest next
May 19, 2009 at 8:17 AM
JDL
  • 16,098 POSTS
Hello, are you saying it cranks good but won't start, or it won't even crank? If the problem is the latter, make sure the battery has a full charge and cables/wires all clean and tight on both ends. Do some testing at the starter relay, the load side of relay is hot all the time, the control side of relay goes hot when you turn the key to the crank position.
If your saying it cranks good but won't start, check for spark at the plugs and fuel pressure, to start.
May 19, 2009 at 8:37 AM
