2000 Plymouth Neon my car hesatates
2000 PLYMOUTH NEON
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHAZZ4444
my car hesatates and my check engine light goes on then after a while it goes off again i think iam getting a misfire could it be a spark plug or a sensor
Apr 26, 2009 at 7:28 AM
CEL coming On -scan the computer for code/s and comeback with it-below is your probable causes:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Apr 26, 2009 at 10:05 AM
