2000 Plymouth Neon ignition switch
2000 PLYMOUTH NEON
65,000 MILES • 4 CYL • FWD • AUTOMATIC
THUMBSS
I have a 2000 plymouth neon that has no keys (lost) Is there a way to have a key made using make model and Vin#or do I have to replace ignition switch and door locks? How do I replace ignition switch w/out key?
Mar 31, 2009 at 11:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The dealer or local locksmith should be able to cut a new key for you without having to replace the lock cylinder..
Thanks for using 2CarPros.com!
Mar 31, 2009 at 12:04 PM
