1999 Plymouth Neon NOT STARTING WHEN COLD
180,451 MILES • 4 CYL • 2WD • AUTOMATIC
LKAYRIT23
COULD YOU TELL ME IF THIS CAR HAS A COLD START VALVE. WHEN IT GETS BELOW40 CAR DOES NOT WANT TO START ACTS LIKE NOT GETTING GAS BUT GAS IS GETTING TO FUEL RAIL SO WOLD THERE BE A CHOKE NOT ENGAGING
Nov 6, 2010 at 8:32 AM
  • 75,988 POSTS
Hot or Cold-Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Nov 7, 2010 at 2:19 AM
