1999 Plymouth Neon improper shifting
1999 PLYMOUTH NEON
125,000 MILES • 4 CYL • FWD • AUTOMATIC
BOWSER91
  • 7 POSTS
the first thing wrong with it is it idles to high and when i put it in drive from park it kicks in gear hard, CV axle ?. also while driving down the highway around 55 or so it does not want to catch the next gear so when I'm going highway speeds its at like 3500\4000rpm. if i feather the gas up to highway speed it catches the next gear but if I'm in it, it does not..and it does not down shift properly either ill slow down to like 25 from 55 or so and give it gas again and it bogs because its in to high of a gear. i bought the car for a dollar so I'm not to worried about it but i need something to drive. can i but a band-aid on it, would a filter/fluid change and some Lucas do the trick ?
May 2, 2010 at 2:10 PM
2 LINSEY
  • 287 POSTS
hi bowser, thank you for the donation. as for the clunk when shifting it into gear, check for bad motor/transmission mounts. The high idle could be due to a dirty idle speed motor or carbon build up in the throttle body, also check for vacum leaks or tears in intake boot. As for the shifting I would definetly start with changing the transmission fluid and filter, and maybe some lucas as well. See what your neon does after that and let me know. good luck
May 5, 2010 at 8:27 AM
BOWSER91
  • 7 POSTS
its not really a clunk it feels like the whole front end jerks forward would it be the same thing ??
May 5, 2010 at 1:46 PM
2 LINSEY
  • 287 POSTS
sounds like it, look in to the motor mounts and trans mount. check to make sure the bolts that hold your cradle up are tight. let me know
May 7, 2010 at 4:29 AM
