1999 Plymouth Neon Hesitates
160,000 MILES • 4 CYL • 2WD • MANUAL
HARLEY COWGIRL
Started hesitating when driven over 60, then it did it all the time. Code said EGR, ignition coil, and heat sensor. Found broke hose to EGR value and replaced it and ignition coil. Then it said missing was told to change plugs, did that. Settled down and dorve it for almost a whole day running great. Then it started again and then if died and would start. After setting for a couple of days it starts and runs. To afraid to dirve it to see if it starts again.
Oct 15, 2010 at 4:52 AM
  • 75,988 POSTS
Check the fuel pressure could be the fuel pump getting weak
Oct 15, 2010 at 5:03 AM
