1999 Plymouth Neon altenater
SCOTT STRICKLAND
1999 Plymouth Neon 4 cyl Two Wheel Drive Automatic
my car has been acting like the battery has been getting drained it was harder and harder to start finally it wouldnt start i took it to auto zone and they said it was the alternator is that it or what
Oct 24, 2010 at 6:27 PM
  • 75,988 POSTS
If they load tested the battery and it checks out-the alternator should be next in line to be load tested if its doing its job if not the electrical system will be just using battery power till its exhausted-then it will results in No crank
Oct 24, 2010 at 10:07 PM
