1998 Plymouth Neon timing belt
1998 PLYMOUTH NEON
THECRAWFORDS4
Engine Mechanical problem
1998 Plymouth Neon 4 cyl Two Wheel Drive Manual
what position are the dowl pins on the cam shafts when both cam sprocks are aligned with the crank shaft at top dead center at number 1 piston
Dec 30, 2009 at 10:04 AM
2.0L DOHC or SOHC ??
Dec 30, 2009 at 10:13 AM
THECRAWFORDS4
2.0 dohc
Dec 30, 2009 at 10:28 AM
See below
https://images.2carpros.com/forum/automotive_pictures/12900_cam1_4.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cam2_5.jpg
Dec 31, 2009 at 6:42 AM
