1998 Plymouth Neon temp gauge
MONICAORTON22
Engine Cooling problem
1998 Plymouth Neon Manual 75000 miles
the temp gauge is peaking several times over and then will drop to normal for a while then do it agian. we have changed the thermostat and it is still doing this. We have pulled the casing to check the belts thinking maybe it was the water pump but belts are fine. It will do this shortly after starting in neg. degree weather even.
We think it has something to do with the reserve.... please help with ideas of what to do next
Feb 23, 2009 at 8:27 AM
  • 110,248 POSTS
Hi:
I would start by replacing the temperature sending unit. It is a cheap part, easy to install, and may be the problem. It is responsible for sending infor to the computer and then to the gauge.
Let me know if this helps.
Mar 21, 2009 at 5:22 AM
