1998 Plymouth Neon Speedometer only works after hitting the
1998 PLYMOUTH NEON
OVERCOMER8
Electrical problem
1998 Plymouth Neon 4 cyl Front Wheel Drive 115000 miles
Please help it is driving me crazy I have a long trip to go on and the speedo was replaced about a year ago the speed sensor about 6 months ago. The speedo goes out after hitting a bump or just while driving on the throughway or any time at all. If I hit the the instruments the speedo begins to work ... what the heck could this be. My friend has cancer and I am making a long trip to see if I can help her and I am nervous I will have a problem with this. SOS... Thank you so much... I just hope I don't have to take the dash out to get to it since I don't see any screws to get to the cluster.!!! Thanks sooooo much.
Sep 6, 2010 at 11:47 AM
BILLYMAC
  • 2,204 POSTS
well you may need to take the cluster out unless you can get your hand behind it unplug the cluster plugs and plug them back in. what you have is a bad connection at the cluster.
Sep 28, 2010 at 11:04 AM
