1998 Plymouth Neon Cooling Fans
87,000 MILES • 4 CYL • FWD • AUTOMATIC
BCROSS1
The cooling fans in my car did not shut off and drained the battery. I jumped the car and the fans remained in. I disconnected the battery and pulled out the fuse for the fans, which shut them off. I re-installed the fuse and re-connected the battery, now the fans won't kick on at all. The temperature gets to well above normal and the fans never kick on. I checked the fuse to make sure it wasn't blown and it isn't. Why won't the fans work now?
Sep 11, 2009 at 11:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check cooling fan relay(s)
Dec 18, 2009 at 9:05 AM
