1998 Plymouth Neon 1998 plymouth neon
1998 PLYMOUTH NEON
55,569 MILES • 4 CYL • FWD • AUTOMATIC
1998PLYMTHNEON
my ? is wut my promblem might be to get my cooling fans to work. I've replaced the temp sensor the frame relay, both fans and nothing so then replaced the PCM the entire motor wiring harness and still nothing the code in the computer is a p1491 that says a open or short in the fan relay curcit. any input would be apriciated
Apr 5, 2009 at 10:48 AM
CARADIODOC
  • 34,321 POSTS
Did you check the fuses?
Apr 5, 2009 at 12:13 PM
1998PLYMTHNEON
yes i've checked all fuses and relays there all good
Apr 5, 2009 at 5:37 PM
