1997 Plymouth Neon timing chain replacement
112,000 MILES • 4 CYL • FWD • MANUAL
JWIZARD105
i just bought the car and was told that there was a timing chaim but i think there is just a belt. Ive seen the belt and it doesnt look bad or loose so what do i do? take the valve cover off and then then head and check everything out just to make sure but what do you guys think i should do??? it is a 2.0 DOHC interference motor.
Mar 20, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle has a timing belt and manufacturer recommends replacing it every 105,000 miles..
Apr 25, 2010 at 9:32 AM
