1997 Plymouth Neon Left Brake Light
145,000 MILES • 4 CYL • FWD • AUTOMATIC
FASTBET35
I have no brake light or turn signal on the left rear of my neon, ive replace the bulbs and the entire light assembly and its still wont work please let me know what i can do next to fix it.
Feb 9, 2010 at 1:46 AM
JDL
  • 16,098 POSTS
Hi, you need to check wiring circuit to lamp assembly. Left side, dark green wire with red tracer, carry voltage for turn and brake, step on the brake, use a testlite, see if wire is hot. Also, black wire is ground, check that as well. The lower brake and turn use the same bulb filament, just not at the same time. Voltage comes from multifunction swich.
Feb 9, 2010 at 1:58 AM
