1997 Plymouth Neon headlights
1997 PLYMOUTH NEON
DARN7PINS
Electrical problem
1997 Plymouth Neon 100k miles
Approx 10 to 15 mn after turning on the headlights they start to blink on and off.
Sep 5, 2009 at 4:54 AM
JDL
  • 16,098 POSTS
Get at the headlamp switch connector, when the problem is ongoing, use a testlite, check voltage at lite green wire, if the voltage is pulsing, I suspect the headlite switch or the feed circuit to the switch.
Sep 5, 2009 at 5:19 AM
