1997 Plymouth Neon head gasket
1997 PLYMOUTH NEON
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
JRJAAR
How much is it to fix a head gasket on this type of model? Leaks a lot of oil, overheated and stopped running. Does it over heat from no water or oil in the engine?
Jul 17, 2009 at 5:55 AM
STEVEW84
  • 673 POSTS
If i had to take a guess. Depending on what area you are in probably starting around $800-$900. Depending on how much damage happened. It will over heat because of a few reasons. One of those reason is having no coolant in it.
Jul 17, 2009 at 6:08 AM
