1997 Plymouth Neon cruise control
125,224 MILES • 4 CYL • 2WD • AUTOMATIC
PETER1116
how do i find out why its not working
Jun 7, 2009 at 7:43 AM
CARADIODOC
  • 34,413 POSTS
That's what mechanics do.
Does the horn work? Is the "Air Bag" light on? Do you have a green "Cruise" light on the dash? If so, does it turn on when you press the button on the steering wheel? These are all clues to the problem. If the "Cruise" light does turn on, suspect a defective section of the brake light switch or the switch is out-of-adjustment. If it doesn't turn on, (or your car doesn't have a green dash light), suspect a defective clock spring under the steering wheel. If that's the case, the horn and air bag systems will eventually be affected too because they all have circuits running through the clock spring.
caradiodoc
Jun 19, 2009 at 11:21 AM
